NXP MFRC522 13.56 MHz RFID无接触读写方案
关键词:通信技术 RFID UART
时间:2009-11-16 10:09:00       来源:NXP
NXP公司的MFRC522 是13.56 MHz 无接触通信的高度集成的读/写IC,支持ISO/IEC 14443 A/MIFARE模式,两个方向的传输速率高达848 kBd. MFRC522工作电压2.5V到3.3V,提供SPI,串行UART和I2C总线接口,具有CRC协处理器和可编程I/O引脚,内部有自测试.本文介绍MFRC522主要特性, 简化和详细方框图, 读/写模式, 总线接口图以及典型应用方框图.
MFRC522: Contactless reader IC
The MFRC522 is a highly integrated reader/writer IC for contactless communication at 13.56 MHz. The MFRC522 reader supports ISO/IEC 14443 A/MIFARE mode.The MFRC522’s internal transmitter is able to drive a reader/writer antenna designed to communicate with ISO/IEC 14443 A/MIFARE cards and transponders without additional active circuitry. The receiver module provides a robust and efficient implementation for demodulating and decoding signals from ISO/IEC 14443 A/MIFARE compatible cards and transponders. The digital module manages the complete ISO/IEC 14443 A framing and error detection (parity and CRC) functionality.
The MFRC522 supports MF1xxS20, MF1xxS70 and MF1xxS50 products. The MFRC522 supports contactless communication and uses MIFARE higher transfer speeds up to 848 kBd in both directions.
The following host interfaces are provided:
• Serial Peripheral Interface (SPI)
查看全文
