Melexis MLX90316无接触旋转定位解决方案
关键词:工业控制 传感器 PWM
时间:2009-10-27 13:25:00       来源:Melexis
Melexis 公司的MLX90316是CMOS霍尔传感器IC,能给出并行于IC表面的磁场角度位置,应用在汽车和工业领域的无接触旋转定位. MLX90316具有高达360度的可编程角度范围,可编程的线性传输特性,可选择模拟,PWM和串行协议控制,12位的角度分辨率和40位ID号码.本文介绍了MLX90316的主要特性, 模拟和PWM的方框图以及串行协议的方框图, 应用电路图,SOIC8和TSSOP16封装的MLX90316连接图, SPI型的单芯片与双芯片的应用框图和单芯片串行协议模式应用框图.
MLX90316: Rotary Position Sensor IC
The MLX90316 is a CMOS Hall sensor that gives the angular position of a magnetic field parallel to the IC surface. It is designed for contactless rotary position sensors that are frequently required in both automotive and industrial applications. The MLX90316 detects the absolute angular position of a small magnet (diametrally magnetized) that is positioned and rotates above the device surface.
查看全文
