Linear LT3754 16路3000:1调光LED驱动方案
关键词:电源管理 LED驱动器
时间:2009-09-22 00:00:00       来源:Linear, , ,
Linear 公司的LT3754 是带升压DC/DC控制器的16路3000:1调光LED驱动器,能驱动高达45V的LED,每路电流的精度在±2.8%,每串LED电流用单个电阻可在10mA-50mA间编程,输出电压能根据LED VF而变,以获得最佳的效率,同时LED开路故障不影响所连接的LED串的工作.LT3754的输入电压从6V到40V,采用PWM调光,调光范围达3000:1,主要用在汽车电子,笔记本电脑和TV监视器的背景光.本文介绍了LT3754的主要特性,方框图以及典型应用电路,包括效率92% 36W背景光LED驱动电路, 6串,每串50mA 36W背景光LED驱动电路,以及32W和17W LED驱动电路.
The LT3754 is a 16-channel LED driver with a step-up DC/DC controller capable of driving up to 45V of LEDs. Each channel contains an accurate current sink with ±2.8% current matching. Channels follow a master programmable current to allow between 10mA to 50mA of LED current per string. Channels can be paralleled for higher LED current. Output voltage adapts to variations in LED VF for optimum efficiency and open LED faults do not affect the operation of connected LED strings.
The LT3754 allows a PWM dimming range up to 3000:1 and an analog dimming range up to 25:1. Operating frequency can be programmed from 100kHz up to 1MHz using a single resistor or synchronized to an external clock.
查看全文
