ADI ADXL345血压计解决方案
关键词:医疗电子 电子血压计
时间:2009-08-28 13:59:00       来源:ADI
ADI公司的血压计解决方案采用3轴±2 g/±4 g/±8 g/±16 g 数字加速度计ADXL345,
12位电容-数字转换器AD7152/AD7153, 全速/低速USB数字绝缘器ADuM4160,单电极容性传感器CapTouch可编程控制器AD7147,以及带低部端口和数字输出的iMEMS麦克风ADMP421等器件.本文介绍了血压计解决方案方框图,以及所采用的主要元器件的主要特性,方框图和应用电路等.
图1.电子血压计方框图
主要元器件介绍:
ADXL345: 3-Axis, ±2 g/±4 g/±8 g/±16 g Digital Accelerometer
The ADXL345 is a small, thin, low power, 3-axis accelerometer with high resolution (13-bit) measurement at up to ±16 g. Digital output data is formatted as 16-bit twos complement and is acces-sible through either a SPI (3- or 4-wire) or I2C digital interface.
The ADXL345 is well suited for mobile device applications. It measures the static acceleration of gravity in tilt-sensing appli-cations, as well as dynamic acceleration resulting from motion or shock. Its high resolution (4 mg/LSB) enables measurement of inclination changes less than 1.0°.
查看全文
