TI TPS51315 10A同步DC-DC转换方案
关键词:电源管理 DC/DC转换器
时间:2009-08-24 11:25:00       来源:TI, , ,
TI 公司的TPS51315是采用D-CAP模式的集成了MOSFET的10A同步DC/DC转换器,输入电压从3V到14V,输出电压从0.75V到5.5V,可连续输出10A电流,关断电流小于5uA, 采用D-CAP模式具有快速瞬态响应. TPS51315提供OVP/UVP/ULVO保护,并集成了可选择的输出放电和热关断特性,主要用于手提设备,笔记本电脑,服务器和台式计算机.本文介绍了TPS51315的主要特性,方框图, 典型的1.05-V/10-A应用电路,和TPS51105一起的1.05-V/10-A应用电路, 以及采用全陶瓷电容输出的应用电路和TPS51315 EVM评估模块的主要特性和电路图.
The TPS51315 is a D-CAP™ mode, 10-A, synchronous switcher with integrated MOSFETs. It is designed for ease of use, low external component count, and small package power systems. The wide switching frequency is programmed with external resistors allowing for optimal efficiency and external component size. D-CAP™ mode allows a low external component count with a fast transient response. The TPS51315 is available in the thermally-efficient, 40-pin QFN 5 mm × 7 mm package and is specified from -40℃ to 85℃.
TPS51315主要特性:
Input Voltage Range: 3 V to 14 V
Output Voltage Range: 0.75 V to 5.5 V
Integrated Power MOSFETs with 10-A Continuous Current Output
< 5-µA Shutdown Current
D-CAP™ Mode with Fast Transient Response
Programmable Switching Frequency with External Resistor From 100 kHz to 1 MHz
查看全文
