Linear LT3070可编输出线性电源稳压方案
关键词:电源管理 DC/DC转换器 LDO线性稳压器
时间:2009-07-30 14:01:00       来源:Linear
Linear 公司的LT3070是5A低噪音可编输出85mV压降的线性稳压器,具有低压超快UltraFast的瞬态响应特性, 0.01μF旁路电容能降低输出电压噪音到25uVRMS.数字可编输出电压从0.8V到1.8V,数字输出富余度为±1%, ±3% 或±5%,两个并联可输出10A电流,线路,负载和温度的调整率为+/-1%.1MHz的35dB,可用于FPGA和DSP电源,ASIC和微处理器电源,服务器和存储设备电源等.本文介绍了LT3070主要特性,方框图, 0.9V 5A 稳压器应用电路和1.5V - 1.2V 线性稳压器电路, 带VIOC降压控制的稳压器电路, 1V/10A点负载电流共享稳压器电路以及三输出(1V/10A,1.8V/5A和1.5V/2.5A)电源电路.
5A, Low Noise, Programmable Output, 85mV Dropout Linear Regulator
The LT3070 is a low voltage, UltraFast™ transient response linear regulator. The device supplies up to 5A of output current with a typical dropout voltage of 85mV.
A 0.01μF reference bypass capacitor decreases output voltage noise to 25μVRMS. The LT3070’s high bandwidth permits the use of low ESR ceramic capacitors, saving bulk capacitance and cost. The LT3070’s features make it ideal for high performance FPGAs, microprocessors or sensitive communication supply applications.
查看全文
