IR公司的IRS254(0,1)是高压(200 V (IRS2540)和600 V (IRS2541))高频降压恒流LED电流调整控制器,采用连续模式时延滞后降压稳压器,直接控制负载平均电流.起动电流小于500uA,140ns死区,片内基准电压±2%,频率高达500kHz.本文介绍了IRS254(0,1)的主要特性,方框图以及采用单个和两个MOSFET的IRS2540应用电路.同时还介绍了采用IRS2540的350mA 到1.5A高压LED驱动器IRPLLED1的电路图和所用材料清单.
The IRS254(0,1) are high voltage, high frequency buck control ICs for constant LED current regulation. They incorporate a continuous mode time-delayed hysteretic buck regulator to directly control the average load current, using an accurate on-chip bandgap voltage reference.
The application is inherently protected against short circuit conditions, with the ability to easily add opencircuit protection. An external high-side bootstrap circuit drives the buck switching element at high frequencies. A low-side driver is also provided for synchronous rectifier designs. All functions are realized within a simple 8 pin DIP or SOIC package.
IRS2540主要特性:
200 V (IRS2540) and 600 V (IRS2541) half bridge driver
Micropower startup (<500 μA)
±2% voltage reference
140 ns deadtime
15.6 V zener clamp on VCC
Frequency up to 500 kHz
Auto restart, non-latched shutdown
PWM dimmable..
查看全文
