Silabs EFM32PG22 Gecko 32位ARM MCU开发方案关键词:ARM Cortex-M33 MCU消费类电子工业应用 SilabsEFM32PG22
时间:2022-1-20 13:34:16 来源:中电网
Silabs公司的EFM32PG22 Gecko MCU是高度效率解决方案,具有有丰富模拟和通信外设的76.8 MHz Cortex-M33内核,提供业界一流的能效的MCU,用于消费类电子和工业应用.器件的内核为32位ARM Cortex-M33,最大工作频率为76.8MHz,有多达512kB闪存和32kB RAM,低能耗工作: 26 uA/MHz (EM0), 1.10 uA睡眠(EM2).器件集成了16路扫描的16位ADC.
Silabs公司的EFM32PG22 Gecko MCU是高度效率解决方案,具有有丰富模拟和通信外设的76.8 MHz Cortex-M33内核,提供业界一流的能效的MCU,用于消费类电子和工业应用.器件的内核为32位ARM® Cortex®-M33,最大工作频率为76.8MHz,有多达512kB闪存和32kB RAM,低能耗工作: 26 uA/MHz (EM0), 1.10 uA睡眠(EM2).器件集成了16路扫描的16位ADC.器件的安全特性包括具有信任根和安全加载程序(RTSL)的安全引导,硬件加密加速用于AES128/256, SHA-1, SHA-2 (多达256位), ECC (多达256位), ECDSA和ECDH,和NIST SP800-90 与AIS-31兼容的真随机号码发生器(TRNG), ARM® TrustZone®,带锁住/解锁的安全调试.单电源1.71V到3.8V工作,工作温度-40 °C到125 °C.主要用在个人卫生设备,电器和白色家电,工业自动化和消费类电子学.本文介绍了EFM32PG22 Gecko MCU主要特性和主要亮点,框图和详细框图,两种典型应用电路,以及PG22 开发板主要特性和主要硬件,框图,电源架构图和外设图,开发板电路图.
The highly efficient solution contains a 76.8 MHz Cortex-M33 with rich analog and communication peripherals to provide an industry-leading, energy efficient MCU for consumer and industrial applications.
EFM32PG22 Gecko MCU主要特性:
• 32-bit ARM® Cortex®-M33 core with 76.8 MHz maximum operating frequency
• Up to 512 kB of flash and 32 kB of RAM
• Low energy operation
• 26 uA/MHz (EM0)
• 1.10 uA sleep (EM2)
• Secure Boot with Root of Trust and Secure Loader (RTSL)
• 16-bit ADC with 16-channel scan
• Personal Hygiene devices
• Appliances and whitegoods
• Industrial Automation
• Consumer electronics
EFM32PG22 Gecko MCU主要亮点:
• Low Power MCU
• High Performance 32-bit 76.8 MHz ARM Cortex®-M33 with DSP instruction and floating-point unit for efficient signal processing
• Up to 512 kB flash program memory
• Up to 32 kB RAM data memory
• Low System Energy Consumption
• 26 μA/MHz in Active ...
