[原创] ST STM8S103F2 8位MCU马达驱动方案
关键词:STM8 MCU 家用电器 STM8S103F2
时间:2015-11-09 09:41:09       作者:ST       来源:中电网
ST公司的STM8S103F2/x3是集成了8KB闪存程序存储器和数据EEPROM,内核工作频率16MHz,具有哈佛架构和3级流水线和扩展指令集,工作电压2.95 到5.5 V,主要用在真空吸尘器,食物处理机和电动工具.本文介绍了STM8S103F2/x3主要特性,框图,评估板STEVAL-IHM029V2主要特性,框图,电路图,材料清单和PCB设计文件图.
The STM8S103F2/x3 access line 8-bit microcontrollers offer 8 Kbytes Flash program memory, plus integrated true data EEPROM. The STM8S microcontroller family reference manual (RM0016) refers to devices in this family as low-density. They provide the following benefits: performance, robustness, and reduced system cost.
Device performance and robustness are ensured by advanced core and peripherals made in a state-of-the art technology, a 16 MHz clock frequency, robust I/Os, independent watchdogs with separate clock source, and a clock security system.
The system cost is reduced thanks to an integrated true data EEPROM for up to 300 k write/erase cycles and a high system integration level with internal clock oscillators, watchdog and brown-out reset.
STM8S103F2主要特性:
Core 
 16 MHz advanced STM8 core with Harvard architecture and 3-stage pipeline 
 Extended instruction set
Memories ..
查看全文
