时间:2013-10-29 10:14:14 作者:Cirrus 来源:CS53L30,低功耗音频,数字音频
Cirrus公司的CS53L30是高性能低功耗四路ADC,其ADC输入具有多种模式如模拟或数字麦克风或线路输入,差分,假差分或单端输入,数字处理特性包括音量控制,静音,可编程高通滤波器和两个数字麦克风接口等.主要用在语音识别系统,高端电话系统,录音机,数码相机和摄像机.本文介绍了CS53L30主要特性,框图, 模拟和数字麦克风连接图,以及评估板CBD53L30主要特性,框图,电路图和PCB元件布局图.
The CS53L30 is a high-performance, low-power, quad-channel ADC. It is designed for use in multiple-mic applications while consuming minimal board space and power.
The flexible ADC inputs can accommodate four channels of analog mic or line-input data in differential, pseudodifferential, or single-ended mode, or four channels of digital mic data. The analog input path includes a +10- to +20-dB boost and a –6- to +12-dB PGA. Digital mic data bypasses the analog gain circuits and is fed directly to the decimators. Four mic bias generators are integrated into the device. The device also includes two digital mic serial clock outputs.
分享到:
