TI公司的LM57是一款集成模拟传感器的精确双路输出温度开关器件,温度阀值可通过两个外部1%精度电阻进行设置。LM57通过外部电阻设置可以实现256种不同温度阀值设置,同时内嵌等比例负温度系数传感器通过VTEMP引脚输出模拟量。本文首先介绍芯片的简介、特性、内部框图及应用领域,并给出相应设计方案的设计原理图、元器件列表及PCB元件布局图。
The LM57 is a precision, dual-output, temperature switch with integrated analog temperature sensor. The trip temperature (TTRIP) is programmable by using two external 1% resistors. Using extremely small packaged resistors (0.5 mm x 1 mm), the LM57 can be programmed to any of 256 trip temperatures while consuming very little board space. The VTEMP output delivers an analog output voltage which is proportional with a negative temperature coefficient (NTC) to the measured temperature.
Built-in temperature hysteresis (THYST) keeps the output stable in an environment of thermal oscillation. The digital temperature switch outputs will go active when the die temperature exceeds TTRIP and will release when the temperature falls below a temperature equal to TTRIP minus THYST. One of the digital outputs, TOVER, is active-high with a push-pull structure. The other digital output, TOVER, is active-low with an open-drain structure.
分享到:
