Cirrus公司的CS1501是高性能数字功率因素修正(PFC)控制器,它能动态管理PFC,从而在很宽负载范围内得到高效率.CS1501具有零电压开关拓扑,欠压锁住(UVLO),输出过压保护,逐个周期的限流,开路/短路保护和热关断,主要用在LCD和LED TV,笔记本电脑,服务器/通信设备.本文介绍了CS1501主要特性,方框图,典型应用电路图以及CS1501 250W高效PFC演示板主要特性,电路图,材料清单和PCB元件布局图表.
The CS1501 is a high-performance digital power factor correction (PFC) controller designed for switching mode power supply (SMPS) applications. The CS1501 actively manages the power factor correction while achieving high efficiency over a wide load range.
The CS1501 adaptively controls the input AC current so that it is in phase with the AC mains voltage, and its waveform mimics the input voltage waveform. The PFC controller executes adaptive digital algorithms designed to shape the AC mains input current waveform to be in phase with the input voltage waveform.
The CS1501 is equipped with a zero-current detection (ZCD) circuit providing the PFC digital controller the capability to turn on the MOSFET when the voltage across the drain and source is near zero. Additionally, a current-sensing circuit is incorporated for instantaneous overcurrent protection.
CS1501主要特性:
• Digital EMI Noise Shaping
分享到:
