NXP BGU7003 1.575 GHz GPS LNA解决方案
关键词:通信技术 无线通信 GPS LNA MMIC
时间:2011-09-28 10:33:15       作者:NXP       来源:BGU7003
NXP公司的BGU7003是宽带硅锗低噪音放大器MMIC,工作频率在40MHz-6GHz,1.575 GHz的噪音NF=0.80dB,插入功率增益为18.3dB,偏压电流通过外接电阻配置,主要用在GPS,卫星无线电,微波通信系统低噪音放大器,WLAN和CDMA以及模拟/数字无绳电话.本文介绍了BGU7003主要特性, 简化方框图, GPS LNA评估板电路图和测量指标,PCB图以及材料清单.
BGU7003: Wideband silicon germanium low-noise amplifier MMIC
The BGU7003 MMIC is a wideband amplifier in SiGe:C technology for high speed, low-noise applications in a plastic, leadless 6 pin, extremely thin small outline SOT891 package.
BGU7003主要特性:
􀂄Low noise high gain microwave MMIC
􀂄Applicable between 40 MHz and 6 GHz
􀂄Integrated temperature stabilized bias for easy design
􀂄Bias current configurable with external resistor
􀂄Noise figure NF = 0.80 dB at 1.575 GHz
􀂄Insertion power gain = 18.3 dB at 1.575 GHz
􀂄110 GHz transit frequency - SiGe:C technology
􀂄Power-down mode current consumption < 1 μA
􀂄Optimized performance at low 5 mA supply current
􀂄ESD protection > 1 kV Human Body Model (HBM) on all pins
BGU7003应用:
􀂄GPS
􀂄Satellite radio
查看全文
