ST 公司的STA350BW是 2x50W 2.1通路数字音频系统,集成了数字音频处理,数字放大器控制和FFX功率输出级。输入电压5V-26V,四路输出配置,25V时能向6欧姆提供2x50W输出功率,100dB SNR和动态范围,输入取样速率在32kHz到192kHz间选择,I2C控制,数字控制增益从+42dB到-80dB,每步分辨率0.125dB。本文介绍了STA350BW主要特性,方框图,单声道并行BTL电路图,电源电路图,立体声BTL模式输出配置图以及STA350BW 2.0通路演示板电路替,输出滤波器电路图和材料清单。
STA350BW:Sound Terminal® 2.1-channel high-efficiency digital audio system
The STA350BW is an integrated solution of digital audio processing, digital amplifier control, and FFX-power output stage, thereby creating a high-power single-chip FFX® solution comprising high-quality, high-efficiency, and all-digital amplification.
The STA350BW is based on an FFX (fully flexible amplification) processor, a proprietary technology from STMicroelectronics. FFX is the evolution and the enlargement of ST’s ternary technology: the new processor can be configured to work in ternary, binary, binary differential and phase-shift PWM modulation schemes.
The STA350BW contains the ternary, binary and binary differential implementations, a subset of the full capability of the FFX processor.
分享到:
