ST STEVAL-ISB005V1低成本锂离子电池充电解决方案
关键词:电源管理 电池充电器
时间:2011-04-12 11:01:01       作者:ST       来源:STEVAL
ST 公司的STEVAL-ISB005V1是采用ST7263BK6和L6924D的低成本锂离子电池充电器演示板,可以采用USB电源或外接DC适配器。充电器的控制采用ST72F63BK6M1微控制器,充电部分采用L6924,采用LED来指示充电状态,主要用在PDA,手持设备,手机和数码相机。本文介绍了STEVAL-ISB005V1主要特性,元件布局图,电路图和
演示板材料清单(BOM)。
STEVAL-ISB005V1:Low-cost Li-Ion battery charger demonstration board based on the ST7263BK6 and L6924D
The STEVAL-ISB005V1 demonstration board is a standalone Li-Ion/ Li-polymer battery charger, which can be powered either by USB or by an external DC adaptor. The ST72F63BK6M1 microcontroller is used for USB enumeration and to control the SD pin of the L6924.
In USB mode, the battery-charging current complies with high-power USB device specifications. The L6924 is powered by 5 V from the USB, thus charging the battery also by USB.
A general-purpose adaptor socket is also available for use when external power is available. In this case, the L6924 operates completely independent of the microcontroller.
STEVAL-ISB005V1主要特性:
■ Can be used both in USB mode and adapter mode
■ Consists of a charger section based on the L6924 for charging a Li-Ion / Li-polymer battery, and an action control section using the ST72F63BK6M1 microcontroller
查看全文
