Cirrus CS3511立体声高效D类音频功率放大方案
关键词:消费类电子 D类音频放大器
时间:2011-01-04 10:03:59       作者:Cirrus       来源:CS3511
Cirrus 公司的CS3511是立体声10W高效D类音频功率放大器,不需要散热器。CS3511集成了过流,过压和超温保护以及误差报告。系统级动态范围为99dB,5W输出时的THD+N为0.025%,通路间隔离为-104dB,单电源9-12V工作,主要用于有源扬声器,数字电视,手提媒体播放器坞站,迷你/微型音乐系统等。本文介绍了CS3511主要特性,方框图,差分和单端输入的立体声放大器电路,以及2 x 11 W CS3511数字放大器参考设计方框图,电路图和参加革命设计元件布局图。
Stereo 10 W High-efficiency Class-D Audio Power Amplifier
The CS3511 is a high-efficiency class-D PWM amplifier that integrates on-chip over-current, under-voltage, over-temperature protection, and error reporting. An onboard regulator generates a 5 VDC supply used to power the internal low-voltage analog and digital circuitry.
The low RDS(ON) outputs can source peak currents up to 2.7 A, deliver high efficiency, allow a small device package, and lower power supply voltage levels. The CS3511 is available in a 32-pin QFN package in Commercial grade (-10℃ to +70℃).
CS3511主要特性:
Closed-loop Advanced Architecture
True Spread Spectrum Modulation
Premium Quality Audio Amplification
– 99 dB Dynamic Range - System Level
– 0.025% THD+N @ 5 W - System Level
– -104 dB Channel Separation
Four Selectable Amplifier Gain Settings
查看全文
