Semtech SC668八路LED驱动管理解决方案
关键词:电源管理 LED驱动器 LDO DC/DC转换器 PWM
时间:2010-12-06 10:33:19       作者:Semtech       来源:SC668
Semtech 公司的SC668是八路LED照明管理单元,具有自动息灯保护,环境光传感器输入,PWM调光等功能和四个200A低噪音LDO稳压器。可驱动8个LED灯,每个灯的电流从0mA 到25mA,电流精度± 1.5%,电流匹配度± 0.5%,具有I2C快模式和标准模式,主要用在手机,智能手机和PDA,LCD模块,手提媒体显示器和数玛相机,PND和键盘背光与LED指示器。本文介绍了SC668主要特性,方框图,典型应用电路以及PCB推荐布局图。
SC668:8 LED Light Management Unit Automatic Dropout Prevention , Ambient Light Sense Input, PWM Dimming, and 4 LDOs
The SC668 is a highly integrated light management unit that provides programmable current for up to eight LED current sinks. Four LED banks are provided to allow set­tings for various LED zones or indicators. Four low-noise LDOs with programmable outputs ranging from 1.2V to 3.3V and 200mA maximum output current are also included.
ADP limits the maximum LED current to a level that ensures the LEDs maintain matched currents when the supply voltage approaches dropout. This feature produces accept­able light output at low supply voltage levels without requiring a boost converter or charge pump.
查看全文
