NXP 公司的TDA19978A集成了均衡器的四路HDMI 1.4a兼容的接收器,并嵌入了EDID存储器,内置的均衡器可改善信号质量,使0.5 mm (24 AWG)电缆长达25米。TDA19978A和标准HDMI 1.4a, DVI 1.0, CEA-861-D 以及HDCP 1.4兼容,HDMI频率高达250MHz,主要用在HDTV,高端TV,YCbCr 或RGB高速视频数字化仪,家庭影院,投映电视,等离子电视和LCD TV等。本文介绍了TDA19978A主要特性,方框图,应用案例框图和应用电路图。
TDA19978A:Quad HDMI 1.4a receiver interface with equalizer (HDTV up to 1080p, up to UXGA for PC formats)
The TDA19978A is a four input HDMI 1.4a compliant receiver with embedded EDID memory. The built in auto-adaptive equalizer improves signal quality and allows the use of cable lengths up to 25 m (laboratory tested with a 0.5 mm (24 AWG) cable at 2.05 gigasamples per second). The HDCP key set is stored in non-volatile One Time Programmable (OTP) memory for maximum security. In addition, the TDA19978A is delivered with software drivers to ease configuration and use.
The TDA19978A supports:
• TV resolutions:
– 480i (1440 480i at 60 Hz), 576i (1440 576i at 50 Hz) to HDTV (up to 1920 1080p at 50/60 Hz)
– WUXGA (1920 1200p at 60 Hz) reduced blanking format
• PC resolutions:
– VGA (640 480p at 60 Hz) to UXGA (1600 1200p at 60 Hz)
分享到:
