时间:2010-11-24 11:19:59 作者:PowerInt 来源:LNK584DG
PowerInt公司的LinkZero-AX系列LNK584DG是零待机功耗离线电源开关器件,具有业界最低待机功耗,在230VAC时为3mW,满足IEC 62301零待机功耗定义,主要用在非隔离的待机电源和辅助电源.本文介绍了LNK584DG产品亮点,功能方框图,典型应用电路以及0.00W待机功耗的1.5W非隔离反激电源参考设计主要特性,电路图以及所用材料清单和变压器电路图.
Ultra low consumption isolated or non-isolated standby and auxiliary supplies
LinkZero-AX LNK584: Zero Standby Consumption Integrated Off-Line Switcher
LinkZero-AX combines extremely low standby/power down energy use with the industry’s lowest component count standby supply solution. Below 3 mW at 230 VAC in power down (PD) mode meets IEC 62301 definition of zero power consumption and is immeasur-able on most power meters. LinkZero-AX is set into PD mode using an external signal to pull the FEEDBACK pin high for 2.5 ms. Such an external signal can be generated by a system micro controller or infrared controller. In PD mode the BYPASS pin remains regulated allowing the LinkZero-AX to be woken up with a reset pulse to pull the BYPASS pin below a reset threshold. Ultra low system consumption is therefore achieved without needing to disconnect the input voltage with a relay.
分享到:
