NS 公司的LM5035C是半桥控制器/栅极驱动器,包括了采用电压模式控制的实现半桥拓扑功率转换器的所有功能。半桥栅极驱动器可达105V/2A,同步整流控制输出可编程延迟。本文介绍了LM5035C主要特性,方框图,评估板电路图,以及1/4砖形高压3.3V 30A电源参考设计主要特性,电路图和所用材料清单(BOM)。
LM5035C:PWM Controller with Integrated Half-Bridge and SyncFET Drivers
The LM5035C Half-Bridge Controller/Gate Driver contains all of the features necessary to implement half-bridge topology power converters using voltage mode control with line voltage feed-forward.
The LM5035C is a functional variant of the LM5035B halfbridge PWM controller. The amplitude of the SR1 and SR2 waveforms are 5V instead of the Vcc level. Also, the soft-stop function is disabled in the LM5035C.
分享到:
