Maxim 公司的MAX15061 是80V 300mW升压电源转换器和电流监视器,包括有恒定频率(400kHz )PWM升压转换器和内部开关,具有高速限流的高侧电流监视器.器件输入电压从2.7V 到11V,输出电压高达76V, 监视功率高达300mW.主要用于雪崩光电二极管偏压和监视, PIN二极管偏压电源,低噪音变容二极管偏压,FBON和GPON模块和LCD显示器.本文介绍MAX15061主要特性, 功能方框图, 典型工作电路和RC滤波器以及VIN = 5.5V 到11V和2.7V 到5.5V的MAX15061典型工作电路.
80V, 300mW Boost Converter and Current Monitor for APD Bias Applications
The MAX15061 consists of a constant-frequency pulsewidth modulating (PWM) step-up DC-DC converter with an internal switch and a high-side current monitor with high-speed adjustable current limiting. This device can generate output voltages up to 76V and provides current monitoring up to 4mA (up to 300mW). The MAX15061 can be used for a wide variety of applications such as avalanche photodiode biasing, PIN biasing, or varactor biasing, and LCD displays. The MAX15061 operates from 2.7V to 11V.
The constant-frequency (400kHz), current-mode PWM architecture provides low-noise output voltage that is easy to filter. A high-voltage, internal power switch allows this device to boost output voltages up to 76V.
分享到:
