Freescale MMA7660FC ZSTAR3无线传感器设计方案
关键词:通信技术 无线传感器 MEMS 物联网
时间:2009-12-15 10:41:00       来源:Freescale, , ,
Freescale 公司的MMA7660FC ZSTAR3无线传感器采用MMA7660FC传感器和MC13213 MCU. MMA7660FC是±1.5 g 3轴带数字输出(I2C)的加速度计,是非常低功耗的小型容性MEMS,具有低通滤波器, 0g失调和增益误差补偿,能以用户可配置的取样速率(1-120次/秒)转换成6位数字值,模拟工作电压2.4V-3.6V,数字电压1.71V-3.6V.而MC13213采用40 MHz HCS08 低压低功耗的内核,有60 KB 闪存和4KB RAM存储器,多个16位计时器,工作电压2V-3.4V. ZSTAR3无线传感器主要应用在手机/PMP/PDA,便携式PC,游戏机和数码相机.本文介绍MMA7660FC和MC13213主要特性,方框图以及802.15.4 标准调制解调器方框图, ZSTAR3 传感器板方框图,电路图和材料清单(BOM).
The MMA7660FC is a ±1.5 g 3-Axis Accelerometer with Digital Output (I2C). It is a very low power, low profile capacitive MEMS sensor featuring a low pass filter, compensation for 0g offset and gain errors, and conversion to 6-bit digital values at a user configurable samples per second. The device can be used for sensor data changes, product orientation, and gesture detection through an interrupt pin (INT). The device is housed in a small 3mm x 3mm x 0.9mm DFN package.
MMA7660FC主要特性:
• Digital Output (I2C)
• 3mm x 3mm x 0.9mm DFN Package
• Low Power Current Consumption: Off Mode: 0.4 μA, Standby Mode: 2 μA, Active Mode: 47 μA at 1 ODR
• Configurable Samples per Second from 1 to 120 samples a second.
查看全文
