关键词:消费类电子 D类音频放大器 手机 数字视频录像机 DVR
时间:2009-10-15 11:15:00 来源:On Semi, , ,
On Semi 公司的NCP2830是1W无滤波器D类音频放大器, 为8.0欧姆(Ω)桥接负载(BTL)提供连续的高质量音频输出,即使输入电压变化,总谐波失真(THD)都低于1%. NCP2830的工作电源电压介于2.7伏(V)与5.5 V,提供200微秒的(µS)的快速启动时间以及-88分贝(dB)的优异电源纹波抑制比(PSRR)。总能效高达89%,并提供100 dB信噪比(SNR)的低噪声性能,主要应用在手机和数码相机,PDA和PMP以及音频配件与GPS.本文介绍了NCP2830的主要特性,方框图,典型应用电路以及差分与单端配置框图.
NCP2830 is a cost effective mono audio power amplifier designed for portable communication device applications such as mobile phones. Due to its integrated charge pump structure, this part is capable of delivering 1 W of continuous average power to an 8.0ohm Bridge Tied Load no matter the voltage provided by a lithium/Ion battery.
NCP2830 is a preferred solution for long playback audio with minimum space required.Added to a fast start−up time of 200 us and a −88dB PSRR, the NCP2830 audio power amplifier is specifically designed to provide high quality and level output power from low supply voltage, requiring very few external components.
NCP2830主要特性:
1 W to 8 _ load for VDD from 2.7 V up to 5.5 V
High quality audio (THD+N = 0.04%)
Low noise: SNR up to 100 dB
Very Fast Turn On Time: 200 us
分享到:
