NXP 公司的TDA8922C是高效率 2x75W D类功率放大器,能向6欧姆扬声器输出2x75W功率, HSOP24和DBS23P封装,工作电压从+/-12.5 V 到 +/-32.5 V,单端应用的增益为30dB,BTL应用的增益为36dB,高效率和低噪音,低静态电流,无噪音起动和关断,具有电压保护和输出限流以及Thermal FoldBack (TFB). TDA8922C主要应用在DVD,迷你和微型接收器,家庭影院和大功率扬声器系统.本文介绍了TDA8922C主要特性, 方框图和典型应用方框图.
2x75 W class-D power amplifier
The TDA8922C is a high-efficiency Class D audio power amplifier. Typical output power is 2 x75 W with a speaker load impedance of 6 ohm.The TDA8922C is available in both HSOP24 and DBS23P power packages. The amplifier operates over a wide supply voltage range from +/-12.5 V to +/-32.5 V and features low quiescent current consumption.
TDA8922C主要特性:
Pin compatible with TDA8950/20C for both HSOP24 and DBS23P packages
Symmetrical operating supply voltage range from +/-12.5 V to +/-32.5 V
Stereo full differential inputs, can be used as stereo Single-Ended (SE) or mono Bridge-Tied Load (BTL) amplifier
High output power in typical applications:
SE 2 x75 W, RL = 6 ohm(VDD = 30 V; VSS = 30 V)
SE 2 x60 W, RL = 8 ohm(VDD = 30 V; VSS = 30 V)
分享到:
