¹Ø¼ü´Ê£ºµçÔ´¹ÜÀí PFC ͼÌÚÖù Onsemi NCP1680
ʱ¼ä£º2022-03-09 16:09:47 À´Ô´£ºÖеçÍø
Onsemi¹«Ë¾µÄNCP1680ÊÇÁٽ絼ͨģʽ¹¦ÂÊÒòÊýУÕý(CRM)PFC¿ØÖÆÆ÷,Éè¼ÆÓÃÓÚÎÞÇÅͼÌÚÖùÍØÆË. ÎÞÇÅͼÌÚÖùPFCÊǹ¦ÂÊÒòËØ¼Ü¹¹,°üÀ¨ÔÚPWM¿ª¹ØÆµÂÊÇý¶¯µÄ¿ìËÙ¿ª¹ØÍȺ͹¤×÷ÔÚACÏß·ƵÂʵĵڶþ¸öÍÈ.ÕâÖÖÍØÆË²»ÐèÒªÔÚͨ³£PFCµç·ÊäÈëËù´æÔڵĶþ¼«¹ÜÇÅ,ÔÊÐí¹¦Âʼ¶Ð§ÂÊÓÐÃ÷ÏԵĸĽø.DCMµÄƵÂÊÕÛ·µ¾ßÓÐ25kHz×îµÍƵÂÊ,·Ç³£Çá¸ºÔØÌõ¼þϲÉÓÃÌøÔ¾Ä£Ê½,רÓõçÁ÷¼ì²â·½°¸,Êý×Öµçѹ»ØÂ·²¹³¥,ACÏß·¼à²âµç·ºÍACÏàλ¼ì²â,ËùÓй¤×÷ģʽ½Ó½ü1µÄ¹¦ÂÊÒòËØ.Ö÷ÒªÓÃÔÚ¹¦ÂÊÒòËØÐÞÕý,ÀëÏßµçÔ´,¹¤ÒµµçÔ´,ͨÐÅ5GµçÔ´,ÍøÂçµçÔ´,ÓÎÏ·¿ØÖÆÌ¨µçÔ´ÒÔ¼°UHD TVµçÔ´.±¾ÎĽéÉÜÁËNCP1680Ö÷ÒªÌØÐÔºÍÓÅÊÆ,²ÉÓÃNCP1680µÄCrMͼÌÚÖùPFCµäÐÍÓ¦Óõç·ÒÔ¼°ÆÀ¹À°åNCP1680 EVBÖ÷ÒªÖ¸±ê,Ö÷°åºÍ×Ó°åµç·ͼ,²ÄÁÏÇåµ¥ºÍPCBÉè¼ÆÍ¼.
The NCP1680 is a CRM PFC controller IC designed to drive the bridgeless totem-pole PFC topology. The bridgeless totem-pole PFC is a power factor correction architecture that consists of a fast switching leg driven at the PWM switching frequency and a second leg that operates at the AC line frequency. This topology eliminates the diode bridge present at the input of a conventional PFC circuit, allowing significant improvement in the power stage efficiency.
NCP1680Ö÷ÒªÌØÐÔ:
Totem Pole PFC Topology Eliminates Input Diode Bridge
Critical Conduction Mode (CRM) Operation
Discontin..
·ÖÏíµ½£º
²ÂÄãϲ»¶
