¹Ø¼ü´Ê£ºµçÔ´¹ÜÀí IGBT Õ¤¼«Çý¶¯Æ÷ Infineon 1ED44175N01B
ʱ¼ä£º2021-09-14 13:57:14 À´Ô´£ºÖеçÍø
Infineon¹«Ë¾µÄ1ED44175N01BÊǵÍѹ¹¦ÂÊIGBT·Ç·´ÏòÕ¤¼«Çý¶¯Æ÷,Âß¼ÊäÈëºÍ±ê×¼CMOS»òLSTTLÊä³ö¼æÈÝ,Êä³öÇý¶¯Æ÷¾ßÓеçÁ÷»º³åÆ÷¼¶.1ED44175N01B¾ßÓÐÓÃÓÚ¹ýÁ÷¼ì²âµÄÒý½ÅºÍFAULT״̬Êä³ö(¼¤»îʱ,EN/FLTÒý½ÅÄÚ²¿ÀµÍ).EN/FLTÐèÒªÍⲿÀ¸ßÒÔÌṩÕý³£¹¤×÷,ÀµÍEN/FLT½ûÓÃÇý¶¯Æ÷.VCCÒý½ÅµÄÄÚ²¿µç·Ìá¹©Ç·Ñ¹Ëø×¡±£»¤,±£³ÖÊä³öµÍµçƽֱµ½VccµçÔ´µçѹÔÚ¹¤×÷·¶Î§ÄÚ.Æ÷¼þ¾ßÓÐ-0.246V¹ýÁ÷ãÐÖµ,¾«¶ÈΪ¡À5% .Æ÷¼þ¾ßÓйýÁ÷¼ì²âºÍ¸ºµçѹÊäÈë,¿É±à¹ÊÕÏÇå³ýʱ¼ä,CMOSÊ©ÃÜÌØ´¥·¢Æ÷ÊäÈë,3.3V,5VºÍ15VÊäÈëÂß¼¼æÈÝ,Ö§³Ö25V VCCµçÔ´µçѹ(×î´ó), 3 kV ESD HBM , RoHS¼æÈÝ.Ö÷ÒªÓÃÔÚסַ¿Õµ÷,Âí´ï,ϵͳ¿ØÖƺͼàÊÓÒÔ¼°´ó¹¦ÂÊ¿ª¹ØµçÔ´.±¾ÎĽéÉÜÁË1ED44175N01BÖ÷ÒªÌØÐÔ,¿òͼºÍÓ¦Óõç·,ÒÔ¼°²ÉÓÃIKW40N65WR5, IDW60C65D1ºÍ1ED441755kWµÄ5kWÁ½Â·½»´íCCM PFCÆÀ¹À°åEVAL-PFC5KIKWWR5SYSÖ÷ÒªÌØÐÔºÍÖ¸±ê,¿òͼ,µç·ͼ,²ÄÁÏÇåµ¥ºÍPCBÉè¼ÆÍ¼.
The 1ED44175N01B is a low-voltage, power IGBT, non-inverting gate driver. Proprietary latch-up immune CMOS technologies enable ruggedized monolithic construction. The logic input is compatible with standard CMOS or LSTTL output. The output driver features a current buffer stage. The 1ED44175N01B has OCP pin for over current protection sense and a FAULT status output (when activivated, EN/FLT pin is internally pulled down). The EN/FLT needs to be externally pulled up to provide normal operation, pulling EN/FLT low disable the driver. Internal circuitry on VCC pin provides an under voltage lockout protection that holds output low until Vcc supply voltage is within operating range..
·ÖÏíµ½£º
²ÂÄãϲ»¶
