[原创]On Semi NVG800A75L4DSC 750V 800A汽车应用方案
关键词:汽车电子 HEV/EV IGBT DC/DC转换器 On Semi NVG800A75L4DSC 750V
时间:2020-11-18 12:35:55       来源:中电网
On Semi公司的NVG800A75L4DSC/D是用于汽车的750V 800A双面冷却的半桥功率模块,具有紧凑的占位面积.模块包括半桥配置的两个场截止式4(FS4) 750V窄台衬底IGBT.芯片组采用新的窄台衬底IGBT技术,以提高大电流密度和强健的短路保护能力和更高的阻断电压,为电动汽车(EV) 牵引动力提供杰出的性能.器件集成了芯片级温度和电流传感器,连续工作温度Tvj max = 175C.具有超低的寄生电感和低VCESAT和开关损耗,采用汽车级FS4和快速二极管芯片技术,DBC衬底隔离4.2kV,具有AEC资质和生产件批准程序(PPAP).主要用在混合和电动汽车牵引动力逆变器和大功率DC/DC转换器.本文介绍了NVG800A75L4DSC/D主要特性,电路图,以及评估板NVG800A75L4DSC−EVK主要特性,简化框图,主要元件图和片上电流检测电路图.
The NVG800A75L4DSC is part of a family of power modules withdual side cooling and compact footprints for Hybrid (HEV) andElectric Vehicle (EV) traction inverter application.
The module consists of two Field Stop 4 (FS4) 750V Narrow MesaIGBTs in a half−bridge configuration. The chipset utilizes the newnarrow mesa IGBT technology in providing high current density androbust short circuit protection with higher blocking voltage to deliveroutstanding performance in EV traction applications.
A dual side liquid cooling heatsink reference design along with acomplete inverter kit (NVG800A75L4DSC−EVK) is available toenable easier design in.
NVG800A75L4DSC主要特性:
• Dual−Side Cooling
• Integrated Chip Level Temp..
查看全文
