[原创]ADI ADAQ4003μModule数据采集解决方案
关键词:μModule 数据采集 DAQ 自动测试设备(ATE) 过程控制 ADI ADAQ4003
时间:2020-10-19 14:47:52       来源:中电网
ADI公司的ADAQ4003μModule®精密数据采集(DAQ)信号链解决方案,可降低精密测量系统的开发周期,优化元件选择和布局.ADAQ4003能保证18位无失码,吞吐速率为2 MSPS,无流水线延迟.动态功耗调节,2 MSPS 时待确定功耗为mW,积分非线性为±0.5 LSB,1 kHz 时SINAD为100 dB(增益 = 0.9),1 kHz时的总谐波失真为−120 dB,100kHz 时为 -100 dB.ADAQ4003具有信号缩放功能的集成式全差分ADC驱动器,增益/衰减为G = 0.45、0.9,1 和 1.9,增益误差为0.005%(典型值),增益漂移为1ppm/C(典型值),兼容串行接口 SPI-/QSPI-/MICROWIRE-/DSP,具有宽输入共模范围,高共模抑制和单端到差分转换.小型 49 球 7x7mm 0.8mm 间距 BGA 封装,宽工作温度范围为−40C 至 +125C.主要用在自动测试(ATE),机器自动化,过程控制,医疗仪器和数字控制回路.本文介绍了ADAQ4003主要特性,功能框图,以及各种增益单端到差分配置图以及差分配置图,以及评估模块EVAL-ADAQ4003FMCZ主要特性,框图,电路图,材料清单和PCB设计图.
 The ADAQ4003 is a μModule® precision data acquisition (DAQ), signal chain solution that reduces the development cycle of a precision measurement system by transferring the signal chain design challenge of component selection, optimization, and layout from the designer to the device.
Using system-in-package (SIP) technology, the ADAQ4003 reduces end system component count by combining multiple common signal processing and conditioning blocks into a single device. These blocks include a high resolution 18-bit, 2 MSPS successive approximation register (SAR), a..
查看全文
