Öйúµç×Ó¼¼ÊõÍø
ÉèΪÊ×Ò³ ÍøÕ¾µØÍ¼ ¼ÓÈëÊÕ²Ø
[Ô­´´]Cypress CY8C62x5 PSoC 6 MCU IoT¿ª·¢·½°¸
¹Ø¼ü´Ê£ºArm Cortex£­M4F MCU ÎïÁªÍø(IoT) Cypress CY8C62x5
ʱ¼ä£º2020-08-25 14:39:03       À´Ô´£ºÖеçÍø
Cypress¹«Ë¾µÄCY8C62x5ÊǸßÐÔÄܳ¬µÍ¹¦ºÄºÍ°²È«PSoC® 6 MCUƽ̨,×éºÏÁËË«CPU΢¿ØÖÆÆ÷ºÍ¾ßÓе͹¦ºÄÉÁ´æ¼¼Êõ,Êý×ֿɱàÂß¼­,¸ßÐÔÄÜÄ£Äâ/Êý×Öת»»ÒÔ¼°±ê׼ͨÐźͼÆÊ±ÍâÉè.Æ÷¼þµÄ32λ˫CPU×Óϵͳ°üÀ¨150MHz Arm® Cortex®-M4F (CM4) CPUºÍµ¥ÖÜÆÚ³Ë·¨Æ÷,¸¡µãºÍ´æ´¢Æ÷±£»¤µ¥Ôª(MPU),100MHz Cortex-M0+ (CM0+) CPUºÍµ¥ÖÜÆÚ³Ë·¨Æ÷ºÍMPU,Óû§¿ÉÑ¡ÔñµÄºËÂß¼­¹¤×÷µçѹÔÚ1.1V»ò0.9V.1.1VºËµçѹʱ¹¤×÷CPUµçÁ÷бÂÊ: Cortex-M4Ϊ40 ¦ÌA/MHz, Cortex-M0+Ϊ 20 ¦ÌA/MHz; 0.9VºËµçѹʱ¹¤×÷CPUµçÁ÷бÂÊ: Cortex-M4Ϊ22 ¦ÌA/MHz, Cortex-M0+Ϊ 15 ¦ÌA/MHz.Æ÷¼þ¾ßÓÐÈý¸öDMA¿ØÖÆÆ÷.´æ´¢Æ÷×Óϵͳ°üÀ¨512KBÓ¦ÓÃÉÁ´æ,32KB¸¨ÖúÉÁ´æ(AUXflash)ºÍ32KB¼àÊÓÉÁ´æ(SFlash),Ö§³Ö±ßд±ß¶Á(RWW)ÒÔ¼°Á½¸ö8KBÉÁ´æ»º³åÆ÷,ÿ¸öCPUÒ»¸ö.´ËÍ⻹°üÀ¨256KB SRAMÒÔ¼°OTP 1Kb eFuseÕóÁÐ.Æ÷¼þµÍ¹¦ºÄ1.7V-3.6V¹¤×÷,Ö÷ÒªÓÃÔÚÎïÁªÍø(IoT).±¾ÎĽéÉÜÁËCY8C62x5ϵÁÐÖ÷ÒªÌØÐÔ,¿òͼºÍʱÖÓ¿òͼ, Ä£Äâ×Óϵͳ¿òͼ, CapSenseÓ²¼þ×ÓϵͳͼÒÔ¼°PSoC 62S1 Wi-Fi BTÏÈ·æ°åÖ÷ÒªÌØÐÔ,¿òͼºÍÒý½ÅͼÒÔ¼°°å°üº¬Ôª¼þ,µç·ͼºÍPCBÉè¼ÆÍ¼.
PSoC® 6 MCU is a high-performance, ultra-low-power and secure MCU platform, purpose-built for IoT applications. The CY8C62x5 product line, based on the PSoC 6 MCU platform, is a combination of a dual CPU microcontroller with low-power flash technology, digital programmable logic, high-performance analog-to-digital conversion and standard communication and timing peripherals.
CY8C62x5ϵÁÐÖ÷ÒªÌØÐÔ:
32-bit Dual CPU Subsystem
¡ö 150-MHz Arm® Cortex..
²é¿´È«ÎÄ
  • ·ÖÏíµ½£º
²ÂÄãϲ»¶
