[原创]ADI ADM2567E 3kV隔离式RS-485收发器解决方案
关键词:消费类电子 HVAC 建筑物自动化 公用事业网络 ADI ADM2567E RS-485
时间:2020-07-10 11:23:39       来源:中电网
ADI公司的ADM2567E是3kV rms信号和电源隔离式的RS-485收发器,满足辐射测试标准EN55032 Class B.器件具有集成的低电磁干扰(EMI),隔离的DC/DC转换器,从而不需要外接的隔离电源.隔离层能满足系统级电磁兼容性(EMC)标准.隔离特性包括RS-485 A, B, Y和Z 引脚的接触性±12 kV ESD保护和空气±15 kV EC61000-4-2 ESD保护.器件还具有电缆反转引脚,允许用户快速修正A,B,Y和Z总线引脚的反向电缆连接,而保持所有接收器故障-安全特性. ADM2565E/ADM2567E的数据速率高达25Mbps.输入VCC电源为3V到5.5V,逻辑VIO电源为1.7V到5.5V,工作温度−40°C到+105°C,共模瞬态免疫度250 kV/μs,支持196总线接点(72 kΩ接收器输入阻抗),具有短路,开路和浮输入接收器故障-安全特性.主要用在HVAC网络,工业现场总线,建筑物自动化和公用事业网络,以及能量计量.本文介绍了ADM2567E主要特性,功能框图,应用案例电路图以及评估板EVAL-ADM2561EEBZ主要特性,电路图,材料清单和PCB设计图.
 The ADM2561E and the pending products within this family (light blue at the top of each page and gray in text) are 3 kV rms signal and power isolated RS-485 transceivers. The devices pass radiated emissions testing to the EN55032 Class B standard with margin on a 2-layer printed circuit board (PCB) using two small external 0402 ferrites on isolated power and ground pins. The device features an integrated, low electromagnetic interference (EMI), isolated dc-to-dc converter, which eliminates the need for an external isolated power supply. The isolation barrier provides immunity to system level el..
查看全文
