Öйúµç×Ó¼¼ÊõÍø
ÉèΪÊ×Ò³ ÍøÕ¾µØÍ¼ ¼ÓÈëÊÕ²Ø
[Ô­´´]Maxim MAX25610Bͬ²½½µÑ¹ºÍ½µ£­ÉýѹLEDÇý¶¯·½°¸
¹Ø¼ü´Ê£ºµçÔ´¹ÜÀí LEDÇý¶¯Æ÷ DC£¯DCת»»Æ÷
ʱ¼ä£º2020-07-03 13:24:49       À´Ô´£ºÖеçÍø
Maxim¹«Ë¾µÄMAX25610A/MAX25610BÊÇȫͬ²½LEDÇý¶¯Æ÷,Ìṩºã¶¨Êä³öµçÁ÷À´Çý¶¯´ó¹¦ÂÊLED. MAX25610A/MAX25610B¼¯³ÉÁËÁ½¸ö60m¦¸¹¦ÂÊMOSFET,ÓÃÓÚͬ²½²Ù×÷ÒÔ×îÉÙ»¯Íâ½ÓÔª¼þ.Æ÷¼þµÄÁé»îÅäÖÃÖ§³Ö½µÑ¹,·´Ïò½µÑ¹-ÉýѹºÍÉýѹת»».Æ÷¼þ²ÉÓõçÁ÷ģʽ¿ØÖÆ,Ìṩ¿ìËÙ˲̬ÏìÓ¦ºÍÈÝÒ×ʵÏÖ»ØÂ·Îȶ¨.Æ÷¼þ»¹°üÀ¨Öð¸öÖÜÆÚµÄµçÁ÷ÏÞÖÆ,Êä³ö¹ýѹ±£»¤(OVP),LED´®¿ªÂ·±£»¤,Êä³ö¶Ì·±£»¤(SCP)ºÍÈȹضÏ.Æ÷¼þÂú×ãÆû³µAEC-Q100¹æ·¶,ÔÚ½µÑ¹-ÉýѹӦÓÃÊäÈëµçѹ´Ó5Vµ½36V,¿ª¹ØÆµÂÊ2.2MHz½µµÍÁ˵ç¸Ð³ß´ç,ÄÚ²¿µçÁ÷¼ì²â½µµÍ³É±¾,¼¯³ÉÁ˸߱ߺ͵ͱ߿ª¹ØMOSFET,´øÄ£Äâ¿ØÖÆµçѹµÄPWMµ÷¹â,´Ó¶ø×îÉÙ»¯µ÷¹âËùÐèÒªÔª¼þÊýÁ¿.¹¤×÷ζÈ-40¡ãC µ½ +125¡ãC,Ö÷ÒªÓÃÔÚÆû³µÕÕÃ÷ºÍ¹¤ÒµÕÕÃ÷.±¾ÎĽéÉÜÁËMAX25610A/BÖ÷ÒªÓÅÊÆºÍÌØÐÔ,¹¦ÄÜ¿òͼºÍ¶àÖÖÓ¦Óõç·,ÒÔ¼°ÆÀ¹À°åMAX25610B EVKÖ÷ÒªÌØÐÔ,µç·ͼ,²ÄÁÏÇåµ¥ºÍPCBÉè¼ÆÍ¼.
 The MAX25610A/MAX25610B are fully synchronous LED drivers that provide constant output current to drive high-power LEDs. The MAX25610A/MAX25610B integrate two 60m¦¸ power MOSFETs for synchronous operation, minimizing external components. Flexible configuration supports buck, inverting buck-boost, and boost conversion. The devices incorporate current-mode control that provides fast transient response and eases loop stabilization. The MAX25610A/MAX25610B include cycle by cycle current limiting, output overvoltage protection (OVP), open-string protection, output short-circuit protection (SCP), and thermal shutdown.
In LED driver applications, the MAX25610A/MAX25610B provide analog dimming of the LED current through th..
²é¿´È«ÎÄ
  • ·ÖÏíµ½£º
²ÂÄãϲ»¶
