[原创] Infineon TLD5099EP多拓扑LITIX功率DC-DC转换器控制方案
关键词:电源管理 DC/DC转换器 LED驱动器 TLD5099EP
时间:2020-04-27 14:09:24       来源:中电网
Infineon公司的TLD5099EP是多拓扑LITIX™功率DC/DC控制器集成电路,灵活使用的确升压控制器,内置了诊断和保护特性,特别适合用来设计驱动LED.它包括脉宽调制器,很容易实现调光功能和降低色彩偏移,它的广谱调制器改善了EMI性能.器件在多种拓扑如升压,降压-升压,SEPIC和反激中支持固定电流和固定电压配置.TLD5099EP以内部5V线性稳压器来驱动低边N沟功率MOSFET.开关频率在100kHz到500kHz间可调,并和外部时钟源同步.输入电压范围从4.5V到45V,模拟调光和PWM调光,调整LED平均电流.主要用在汽车外部和内部照明,通用照明以及通用电流/电压控制DC/DC驱动器.中电网为您整理如下详细资料,本文介绍了TLD5099EP主要特性,框图和开关稳压器框图,多种应用电路,以及大功率LED应用评估板主要特性,电路图,材料清单和PCB设计图.
The TLD5099EP is a flexibly usable DC/DC boost controller with built in diagnosis and protection features especially designed to drive LEDs. It also includes a pulse width modulator to easily implement a dimming function with reduced color shifting and a spread spectrum modulator to improve the EMI performance.
It is designed to support fixed current and fixed voltage configurations in multiple topologies such as Boost, Buck, Buck-Boost, SEPIC and Flyback by simply adjusting the external components. The TLD5099EP drives a low side n-channel power MOSFET from an internal 5 V linear regulator.
查看全文
