[原创] Infineon 1200V IM818-MCC IPM马达驱动解决方案
关键词:电源管理 马达驱动 IPM IGBT
时间:2019-08-22 11:41:39       来源:中电网
infineon公司的IM818是CIPOS™Maxi IPM系列产品中成员,集成了各种功率和控制元件,以增加可靠性,优化PCB尺寸和系统成本.设计用来控制可变速度驱动应用的三相AC马达和永磁马达如低功耗马达驱动(GPI,伺服驱动),泵,风扇驱动和HVAC(加热、通风和空调)的有源滤波器.器件特别适合于需要良好热性能和电隔离以及EMI保存控制与过载保护的功率应用.具有1200V TRENCHSTOP™ IGBT和发射极控制二极管的三相逆变器和优化六路SOI栅极驱动器组合在一起,以得到最好的性能.器件具有过流关断,内置的温度计用来温度监视器,所有通路欠压锁住,能防止交叉导通,所有的六个开关在保护时是断开的,可编程故障清除时序和使能输入, RoHS兼容.主要案用在HVAC,泵和低功率马达驱动(GPI,伺服驱动)的风扇驱动和有源滤波器.本文介绍了Maxi IM818主要特性, 内部电路图,典型应用电路图以及评估板EVAL-M1-IM818-A主要特性,框图,电路图,材料清单和PCB设计图.
The CIPOS™ Maxi IM818 product group offers the chance for integrating various power and control components to increase reliability, optimize PCB size and system costs. It is designed to control three phase AC motors and permanent magnet motors in variable speed drives applications such as low power motor drives (GPI, Servo drives), pumps, fan drives and active filter for HVAC(Heating, Ventilation, and Air Conditioning). The product concept is specially adapted to power applications, which need good thermal performance and electrical isolation as well as EMI save control and overload protection.
Three phase inverter with 1200V TRENCHSTOP™ IGBTs and Emitter Controlled diodes are combined with an optimized 6-channel SOI gate driver for excellent electrical performance.
Maxi IM818主要特性:
 Fully isolated Dual In-Line molded module
 1200V TRENCHSTOP™ IGBT4
 Rugged 1200V SOI gate driver technology with stability against transient and negative voltage
 Allowable negative VS potential up to -11 V for signal transmission at VBS = 15 V
 Integrated bootstrap functionality
 Over current shutdown
 Built-in NTC thermistor for temperature monitor
 Under-voltage lockout at all channels
 Low side emitter pins accessible for all phase current monitoring (open emitter)
 Cross-conduction prevention
 All of 6 switches turn off during protection
 Programmable fault clear timing and enable input
 Lead-free terminal plating; RoHS compliant
Maxi IM818主要应用:
Fan drives and active filter for HVAC, pumps, and low power motor drives (GPI, Servo Drives)
图1.Maxi IM818内部电路图
图2.Maxi IM818典型应用电路图
评估板EVAL-M1-IM818-A
EVAL-M1-IM818-A is a complete evaluation board including a 3-phase CIPOS™ Maxi Intelligent Power Module(IPM) for motor drive application. In combination with control-boards equipped with the M1 20pin interfaceconnector, like EVAL-M1-101T or EVAL-M1-099M, it features and demonstrates Infineon’s CIPOS™ Maxi IPMtechnology for motor drive.
The evaluation board EVAL-M1-IM818-A was developed to support customers during their first stepsdesigning applications with CIPOS™ Maxi IPM.
CIPOS™ Maxi IPM in this board is IM818-MCC which has three phase inverter with 1200V TRENCHSTOP™IGBTs and Emitter Controlled diodes are combined with an optimized 6-channel SOI gate driver. It isOptimized to industrial applications like Ventilation and Air Conditioning.
The EVAL-M1-IM818-A evaluation board is a part of the iMOTION™ Modular Application Design Kit for drives(iMOTION™ MADK).
The MADK platform is intended to use various power stages with different control boards. These boards caneasily be interfaced through the iMOTION™ MADK M1 interface connector which is 20 pin connector.
This evaluation board is designed to give easy-to-use power stage based on the Infineon ’ s CIPOS™ MaxiInteligent Power Module (IPM). The board is equipped with all assembly circuit for sensorless field orientedcontrol (FOC). It provides a single-phase AC-connector, rectifier and 3-phase output for connecting themotor. The power stage also contains emitter (leg) shunts for current sensing and a voltage divider for DClinkvoltage measurement.
The EVAL-M1-IM818-A evaluation board is available through regular Infineon distribution partners as well ason Infineon’s website. The features of this board are described in the design feature chapter of thisdocument, whereas the remaining paragraphs provide information to enable the customers to copy, modifyand qualify the design for production according to their own specific requirements.
Environmental conditions were considered in the design of the EVAL-M1-IM818-A. The design was tested asdescribed in this document but not qualified regarding safety requirements or manufacturing and operationover the whole operating temperature range or lifetime. The boards provided by Infineon are subject tofunctional testing only.
Evaluation boards are not subject to the same procedures as regular products regarding Returned MaterialAnalysis (RMA), Process Change Notification (PCN) and Product Discontinuation (PD). Evaluation boards areintended to be used under laboratory conditions and by trained specialists only.
The block diagram of the EVAL-M1-IM818-A is depicted in Figure 1. This evaluation board includes a DC EMIfilter and soft power up circuit, 20-pin iMOTION™ MADK-M1 interface connector, auxiliary power supply toprovide 15 V and 3.3 V, and the CIPOS™ Maxi IPM IM818-MCC.
图3.评估板EVAL-M1-IM818-A框图
评估板EVAL-M1-IM818-A主要特性:
EVAL-M1-IM818-A is an evaluation board for motor drive applications based on a 3-phase IPM. Combinedwith one of the available MADK control board options, it demonstrates Infineon’s IPM technology for motordrives. The kit demonstrates Infineon’s IPM technology for motor drives.
• 1200 V TRENCHSTOP™ IGBT4
• Maximum blocking voltage VCES = 1200 V
• Maximum output current at 25 °C case temperature IC = 16 A
• Rugged 1200 V SOI gate driver technology with stability against transient and negative voltage
• Allowable negative VS potential up to -11 V for signal transmission at VBS = 15 V
• Integrated bootstrap functionality
• Overcurrent shutdown
• Built-in NTC thermistor for temperature monitoring
• Under-voltage lockout at all channels
• Low side emitter pins accessible
• For all phase current monitoring (open emitter)
• Cross-conduction prevention
• All of 6 switches turn off during protection
• Programmable fault clear timing and enable input
• Lead-free terminal plating; RoHS compliant
The evaluation board characteristics are:
• Nominal input voltage 380 VAC
• Default 1.5 kW motor power output
• On board EMI filter
• Current sensing for each leg configured by default
• Sensing of DC-link voltage
• Measurement test-points compatible to standard oscilloscope probes
• PCB size is 197 mm x 140 mm and has two layers with 35 μm copper each
• RoHS compliant
评估板EVAL-M1-IM818-A主要指标:
图4.评估板EVAL-M1-IM818-A顶层的功能组图
图5.评估板EVAL-M1-IM818-A和EVAL-M1-101T系统连接图
图6.评估板EVAL-M1-IM818-A EMI滤波器和AC/DC部分电路图
图7.评估板EVAL-M1-IM818-A EMI采用CIPOS Maxi IPM的三相逆变器部分电路图
图8.评估板EVAL-M1-IM818-A EMI电源部分电路图
图9.评估板EVAL-M1-IM818-A电路图
评估板EVAL-M1-IM818-A材料清单:
图10.评估板EVAL-M1-IM818-A顶层装配图
图11.评估板EVAL-M1-IM818-A底层装配图
图12.评估板EVAL-M1-IM818-A顶层PCB布局图
图13.评估板EVAL-M1-IM818-A底层PCB布局图
详情请见:
https://www.infineon.com/dgdl/Infineon-IM818-MCC-DataSheet-v02_02-EN.pdf?fileId=5546d46265f064ff0165f9e91e3c2e9e
f460167bb2df0121ab1">https://www.infineon.com/dgdl/Infineon-AN2018-35_EVAL-M1-IM818-A_User_Manual-UM-v01_01-EN.pdf?fileId=5546d462677d0f460167bb2df0121ab1
Infineon-AN2018-35_EVAL-M1-IM818-A_User_Manual-UM-v01_01-EN.zip
