关键词:PolarFire FPGA 无线通信 智能光模块 视频广播
时间:2019-04-11 10:34:40 来源:中电网
Microsemi公司的PolarFire™ FPGA是第五代非易失FPGA器件,采用28nm非易失工艺技术,采用业界最低功耗的FPGA构造,最低功耗12.7Gbps收发器通路,内置了低功耗双PCI Express Gen2 (EP/RP),以及可选择数据安全器件,低功耗加密协处理器.因此具有最佳的成本器件,并提供中等密度器件的最低功耗.PolarFire™ FPGA有多达481K逻辑单元,包括有可断裂D型触发器的4输入查找表(LUT),20Kb双或两端口大静态随机存储器(LSRAM)区块,64x12两端口区块,具有预加器,48位累加器的18x18数学区块,以及可选择16深x18系数ROM,高速串行连接性,内置了多吉比特和多协议收发器,速度从250Mbps到12.7 Gbps,高速I/O(HSIO)支持高达1600 Mbps DDR4, 1333 Mbps DDR3L和1333 Mbps,集成了I/O数字的LPDDR3/DDR3存储器,PolarFire™ FPGA工作在1.0V和1.05V电压,商用温度(0℃- 100℃) 和工业温度(–40℃-100℃).主要用在有线接入网(1G-40G),无线异构网络,无线骨干网,智能光模块以及视频广播.本文介绍了MPF300 PolarFire™ FPGA主要特性,框图和收发器通路模式图,评估板MPF300-VIDEO-KIT主要特性和框图,电路图和PCB设计图.
PolarFire™ FPGAs are the fifth-generation family of non-volatile FPGA devices from Microsemi, built onstate-of-the-art 28nm non-volatile process technology. Cost-optimized PolarFire FPGAs deliver thelowest power at mid-range densities. PolarFire FPGAs lower the cost of mid-range FPGAs by integratingthe industry’s lowest power FPGA fabric, lowest power 12.7 Gbps transceiver lane, built-in low powerdual PCI Express Gen2 (EP/RP), and, on select data security (S) devices, an integrated low-power crypto co-processor. PolarFire FPGAs can operate a..
分享到:
