[原创] On Semi CP51705单路6ASiC MOSFET驱动方案
关键词:电源管理 SiC MOSFET AC/DC转换器 DC/DC转换器 马达驱动
时间:2018-06-26 10:43:24       作者:On Semi       来源:中电网
On Semi公司的CP51705是单路6A高速低边SiC MOSFET驱动器,源电流和沉电流6A,为了获得最低的导通损耗,驱动器能对SiC MOSFET提供最大限度的栅极电压,主要用在驱动SiC MOSFET器件,工业逆变器,马达驱动器以及PFC,AC/DC转换器和DC/DC转换器.本文介绍了CP51705主要特性,框图和应用电路,以及评估板EVBUM2528/D,电路图,材料清单和PCB设计图.
The NCP51705 driver is designed to primarily drive SiC MOSFETtransistors. To achieve the lowest possible conduction losses, thedriver is capable to deliver the maximum allowable gate voltage to theSiC MOSFET device. By providing high peak current during turn−onand turn−off, switching losses are also minimized. For improvedreliability, dV/dt immunity and even faster turn−off, the NCP51705can utilize its on−board charge pump to generate a user selectablenegative voltage rail.
For full compatibility and to minimize the complexity of the biassolution in isolated gate drive applications the NCP51705 alsoprovides an externally accessible 5 V rail to power the secondary sideof digital or high speed opto isolators.
The NCP51705 offers important protection functions such asunder−voltage lockout monitoring for the bias power and thermalshutdown based on the junction temperature of the driver circuit.
CP51705主要特性:..
查看全文
