[原创] Linear LTC7821混合降压同步电源转换解决方案
关键词:电源管理 DC/DC转换器 LTC7821
时间:2018-04-13 10:38:41       作者:Linear       来源:中电网
Linear公司的LTC7821是混合降压同步电源转换控制器,把软开关电荷泵拓扑和同步降压转换器组合起来,提供高达97%的效率和更好的EMI性能,VIN输入电压10V-72V,可锁相固定频率200kHz到1.5MHz,输出电压精度±1%,可编CCM,DCM或突发模式工作,主要用在中间总线转换,大电流分布电源系统,通信,数据通信和存储系统.本文介绍了LTC7821主要特性,框图,应用电路,以及演示板DC2513A主要指标,测量建立图,电路图和材料清单.
The LTC®7821 uses a proprietary architecture that mergesa soft switching charge pump topology with a synchronousstep-down converter to provide superior efficiencyand EMI performance compared to traditional switchingarchitectures.
In a typical 48V to 12V application, efficiency of greaterthan 97% is attainable with the LTC7821 switching at500kHz. The same efficiency can only be achieved with atraditional controller switching at one-third the frequency.
Higher switching frequencies allow the use of smaller inductancesthat yield faster transient response and smallersolution size.
The LTC7821 can be easily paralleled to provide higheroutput currents with its accurate current sharing capabilityand frequency synchronization function.
LTC7821主要特性:
Wide VIN Range: 10V to 72V (80V ABS Max)
Soft Switching for Low Noise Operation
Phase-Lockable Fixed Frequency 200kHz to 1.5MHz..
查看全文
