[原创] On Semi RSL10超低功耗多协议蓝牙5 SoC解决方案
关键词:无线通信 物联网(IoT) 系统级芯片(SoC) RSL10
时间:2018-03-06 10:30:52       作者:On Semi       来源:中电网
On Semi公司的RSL10超低功耗多协议蓝牙5系统级芯片(SoC),采用1.2V和1.5V电池工作,支持工作电压在1.1V和3.3V之间;器件具有双核架构和2.4GHz收发器,深睡眠模式功耗62.5nW,接收模式Rx功耗为7mW,接收灵敏度-94 dBm,发送功率-17 dBm到 +6 dBm.器件还集成了高效功率管理单元,振荡器,闪存,RAM,DMA控制器,外设和接口.主要用在超低功耗IoT超低功耗连接,以及心率监视器等.本文介绍了RSL10主要特性,框图和架构图,降压模式和LDO模式应用框图以及评估板EVBUM2529/D主要特性,电路图和材料清单.
ON Semiconductor’s RSL10 is a multiprotocol Bluetooth 5 certified radio SoC, which brings ultra-low-power wireless technology to IoT. Offering the industry’s lowest power consumption, RSL10 helps provide devices like heart rate monitors with advanced wireless features while optimizing system size and battery life.
Unlike most other multi-protocol radio SoCs, RSL10 is specifically designed for applications using 1.2 V and 1.5 V batteries, and supports a voltage supply range between 1.1 V and 3.3 V without a required DC/DC converter. The highly-integrated radio SoC features a dual-core architecture and a 2.4 GHz transceiver, providing the flexibility to support Bluetooth low energy technology and 2.4 GHz proprietary or custom protocols.
RSL10主要特性:
查看全文
