[原创] TI AMIC110多协议可编工业通信处理器开发方案
关键词:工业控制 以太网 工业通信 AMIC110
时间:2017-06-27 10:10:40       作者:TI       来源:中电网
TI公司的AMIC110是多协议可编工业通信处理器,基于Sitara™ARM Cortex-A8 32位RISC处理器,工作频率高达300MHz,支持高级操作系统(HLOS),集成了NEON™ SIMD协处理器,外设和工业接口,32KB L1指令缓存和32KB数据缓存,256KB L2缓存,176KB引导ROM,64KB专用RAM,64KB通用片上存储器控制器(OCMC) RAM.协议包括EtherCAT, PROFINET IRT, EtherNet/IP, PROFIBUS, Ethernet Powerlink, Sercos III.主要用在工业通信,连接工业驱动器和背板I/OI.本文介绍了AMIC110主要特性,功能框图,以及AMIC110工业通信引擎(ICE)开发平台主要特性,框图,电路图,材料清单和PCB设计图.
The AMIC110 device is a multiprotocol programmable industrial communications processor providingready-to-use solutions for most industrial Ethernet and fieldbus communications slaves, as well as somemasters. The device is based on the ARM Cortex-A8 processor, peripherals, and industrial interfaceoptions. The device supports high-level operating systems (HLOS). Linux® and TI-RTOS are available freeof charge from TI. Other RTOS are also offered by TI ecosystem partners. The AMIC110 microprocessoris an ideal companion communications chip to the C2000 family of microcontrollers for connected drives.
查看全文
