[原创] PowerInt INN2215K18W USB-PD快速充电参考设计DER-567
关键词:电源管理 USB-PD QC 3.0
时间:2017-05-16 10:35:33       作者:PowerInt       来源:中电网
PowerInt公司的InnoSwitch-CP系列INN2215K是离线CV/CC反激开关集成电路,集成了650V MOSFET,Sync-Rect反馈和用于USB-PD和QC 3.0的恒功率分布图,大大简化了低压大电流电源特别是小尺寸和高效率电源的开发和制造.支持快速充电协议USB-PD 和QC 3.0,隔离电压大于3,500 VAC ,UL1577和TUV (EN60950)安全认证,和EN61000-4-8 (100 A/m) 以及EN61000-4-9 (1000 A/m)兼容,主要用在QC 3.0和USB-PD充电器.本文介绍了InnoSwitch-CP系列INN2215K产品优势和主要特性,初级边和次级边控制器框图,简化应用电路,以及采用Weltrend WT6630P和INN2215K的18W USB-PD电源参考设计DER-567主要特性,主要指标,电路图,材料清单和PCB设计图和变压器电路图.
The InnoSwitch™-CP family of ICs dramatically simplify the development and manufacturing of low-voltage, high current power supplies, particularly those in compact enclosures or with high efficiency require­ments. The InnoSwitch-CP architecture is revolutionary in that the devices incorporate both primary and secondary controllers, with sense elements and a safety-rated feedback mechanism into a single IC.
Close component proximity and innovative use of the integrated communication link permit accurate control of both a secondary-side synchronous rectification MOSFET and optimization of primary-side MOSFET switching. This improves system reliability, maximizes efficiency across the entire load range and achieves no-load consump­tion of less than 10 mW.
INN2215K产品优势:
Highly Integrated, Compact Footprint
Incorporates flyback controller, 650 V MOSFET, secondary-side sensing and synchronous rectification driver
Supports fast charge protocols such as USB-PD and QC 3.0
Minimizes charging time with continuous adjustment of output current and voltage
Optimizes transformer and external components
FluxLink™ integrated, HIPOT-isolated, feedback link
Exceptional CV accuracy, tolerant of transformer and board component variances
EcoSmart™– Energy Efficient
<10 mW no-load at 230 VAC when supplied by transformer bias winding
Easily meets all global energy efficiency regulations
Advanced Protection / Safety Features
Primary sensed output OVP
Secondary sensed output overshoot clamp
Secondary sensed constant current with 3 V auto-restart
Hysteretic thermal shutdown
Input voltage monitor with accurate brown-in/brown-out and overvoltage protection
Full Safety and Regulatory Compliance
100% production HIPOT compliance testing equivalent to 6 kV DC/1 sec
Reinforced insulation
Isolation voltage >3,500 VAC
UL1577 and TUV (EN60950) safety approved
EN61000-4-8 (100 A/m) and EN61000-4-9 (1000 A/m) compliant
Green Package
Halogen free and RoHS compliant
INN2215K应用:
QC 3.0 and USB-PD chargers
图1.INN2215K初级边控制器框图
图2.INN2215K次级边控制器框图
图3.INN2215K典型应用框图
图4.INN2215K 5V/3A,9V/2A,12V/1.5A QC3.0兼容充电器/适配器电路图
This document is an engineering report describing a 5 V, 3 A or 9 V, 2 A output USB Type-C and USB-PD charger using the InnoSwitch-CP and Weltrend WT6630P USB Type- C USB-PD controller. This design shows the high power density and efficiency that is possible due to the high level of integration of the InnoSwitch-CP controller providing exceptional performance.
This document contains the power supply specification, schematic, bill of materials, transformer documentation, printed circuit layout, and performance data.
18W USB-PD电源参考设计DER-567主要特性:
• InnoSwitch-CP industry first AC/DC IC with isolated, safety rated integrated feedback
• USB-PD compliance via single secondary side IC (Weltrend WT6630P)
• All the benefits of secondary-side control with the simplicity of primary-side regulation
• Insensitive to transformer variation
• Built in synchronous rectification for high efficiency
• Meets DOE6 and CoC V5 2016 at the end of cable (cable impedance ≤100 mΩ)
• <30 mW no-load input power
• >84.9% efficiency for 9 V, 2 A for all line conditions
• >87 % efficiency for 9 V, 2 A and 230 VAC input
• >8% CoC Tier 2 efficiency margin for 10% load
• Integrated thermal protection
• Primary sensed overvoltage protection
图5.18W USB-PD电源参考设计DER-567外形图(正面)
图6.18W USB-PD电源参考设计DER-567外形图(背面)
18W USB-PD电源参考设计DER-567主要指标:
图7.18W USB-PD电源参考设计DER-567电路图
图8.18W USB-PD电源参考设计DER-567变压器电路图
图9.18W USB-PD电源参考设计DER-567 PCB设计图(正面)
图10.18W USB-PD电源参考设计DER-567 PCB设计图(背面)
详情请见:
ac-dc.power.com/design-support/product-documents/data-sheets/innoswitch-ce-data-sheet/">https://ac-dc.power.com/design-support/product-documents/data-sheets/innoswitch-ce-data-sheet/
https://ac-dc.power.com/design-support/reference-designs/design-examples/der-567-18-w-usb-pd-power-supply/?utm_campaign=innoswitch-cp_der567&utm_medium=referral&utm_source=pi&utm_content=pressrelease&utm_term=ac-dc+innoswitch-cp+usbpd+pi+en&AdSource=PRen_DER567
der567.pdf
innoswitch-cp_family_datasheet.pdf
