[原创] Microchip Explorer 8开发板解决方案DM160228
关键词:PIC MCU Explorer 8 DM160228
时间:2016-11-25 09:40:33       作者:Microchip       来源:中电网
Microchip公司的Explorer 8开发板是用来评估和演示8位PIC MCU的多用途全功能最新开发平台,支持8/14/20/28/40引脚DIP和44/64/80引脚PIM安装的PIC MCU,支持多个调试和编程解决方案,包括PICktt™ 3、ICD 3 和 MPLAB® REAL ICE™ 在线仿真器,具有三个单独的电源如5V,3.3V 和可变 (1.5-4.5V)以及16 x 2 字符LCD 显示屏.本文介绍了PIC16LF1554/1559 8位PIC MCU主要特性,框图和Explorer 8开发板主要特性,主要元件分布图,电路图和PCB元件布局图.
The PIC16LF1554/1559 microcontrollers with Microchip enhanced mid-range core deliver unique on-chip features forthe design of mTouch® solutions and general purpose applications in 14/20-pin count packages. Two 10-bithigh-speed ADCs with automated hardware CVD modules connect to up to 17 analog channels to achieve a totalsampling rate of 600k samples per second. Combined with two PWMs and multiple communication peripherals, thismicrocontroller family is an excellent solution to implement low-power and noise-robust capacitive sensing and otherfront-end sampling applications with minimal software overhead.
PIC16LF1554/1559主要特性:
High-Performance RISC CPU
• Only 49 Instructions to Learn
• Operating Speed:
- DC – 32 MHz clock input
- DC – 125 ns instruction cycle..
查看全文
