[原创] NXP KinetisKV1x系列BLDC马达控制系统参考设计
关键词:ARM Cortex-M0+ MCU BLDC马达控制
时间:2016-06-22 11:18:58       作者:NXP       来源:中电网
NXP公司的Kinetis KV1x系列MCU采用ARM Cortex-M0+核,采用创新的90nm薄膜存储(TFS)闪存工艺技术,工作频率高达75MHz,集成了多达128 KB闪存和16KB RAM,非常适合用于工业马达控制,逆变器和低端电源转换器.本文介绍了Kinetis KV1x系列主要特性,框图,以及BLDC马达控制参考设计FRDM-KV10Z主要特性,框图,和电路图.
The Kinetis V Series KV11x MCU family is built on ARM Cortex-M0+ core and enabled by innovative 90nm thin film storage(TFS) flash process technology. The KV11x is an extension ofthe existing KV10x family providing increased memory, higherpin count, additional FTMs and a FlexCAN serial interface.
KV11x is ideal for industrial motor control applications, inverters,and low-end power conversion applications.
Kinetis KV1x系列主要特性:
Performance
• Up to 75 MHz ARM Cortex-M0+ based core
Memories and memory interfaces
• Up to 128 KB of program flash memory
• Up to 16 KB of RAM
System peripherals
• Nine low-power modes to provide power optimizationbased on application requirements
• 8-channel DMA controller
• SWD interface and Micro Trace buffer
• Bit Manipulation Engine (BME)
• External watchdog timer
• Advanced independent clocked watchdog..
查看全文
