[原创] Cypress S6AP413A 多路DC-DC转换解决方案
关键词:电源管理 DC/DC转换器 S6AP413A
时间:2016-02-23 10:59:01       作者:Cypress       来源:中电网
Cypress公司的S6AP413A是三路降压DC/DC转换器和一路降压-升压DC/DC转换器,采用电流模式控制,输入电压2.5V-5.5V,输出电压有多种:D1:0.7V- 1.32V (20 mV/步),D2:1.2V - 1.95V (50 mV/步),D3:2.8V to 3.5V (100 mV/步),D4:0.7V to 1.32V (20 mV步),最大输出电流DD1:2A, DD2:1.2A, DD3:0.6A, DD4:2A.有多种保护功能,主要用在网络设备,工厂自动化,安全系统,监视摄像机,电子音乐设备,多功能打印机,复印机,家用电器,数据存储和移动设备等.本文介绍了S6AP413A主要特性,框图和应用电路,以及S6AP413A评估板电路图,材料清单和PCB设计图.
S6AP413A contains 3ch buck DC/DC converter and 1ch buck-boost DC/DC converter. S6AP413A cansupply the main power line in several systems by using only its chip. The current mode control is adopted forthe DC/DC converter, and it is possible to use the small chip inductor with the high switching frequencyoperation which contains internal switching FETs. S6AP413A contains the output setting resistor and thephase compensation circuit, and contributes to reduce the number of external components and its mountarea. Also it contains the CTL input pin which can control the ON/OFF for each DC/DC converter, the PowerGood signal output pin and I2C communication interface, therefore it is easy to design the power supplysequence. It is possible to tune in the output voltage exactly using the I2C communication.
S6AP413A主要特性:..
查看全文
