[原创] NXP SSL5257TE11.5 W LED驱动解决方案
关键词:电源管理 LED驱动器 SSL5257TE 升压-降压控制器
时间:2015-11-12 10:46:36       作者:NXP       来源:中电网
NXP公司的SSL5257TE是高集成高精度升压-降压控制器,内部集成了MOSFET,效率高达90%,用来驱动低成本小型可调光的10W LED灯.本文介绍了SSL5257TE主要特性和优势,框图和应用框图,演示板SSL5257DB1291主要指标,电路图,材料清单和PCB设计文件.
The SSL5257TE is a highly integrated, high-precision buck-boost controller with an internal MOSFET. It is intended to drive low-cost compact dimmable LED lamps up to 10 W. The SSL5257TE is designed to achieve high power factor, phase-dimmable applications.
The SSL5257TE operates in Boundary Conduction Mode (BCM) with on-time control. It regulates a constant output current over line and load variations. The wide switching frequency range makes it possible to choose an inductor, which enables the optimization of inductor size, efficiency and EMI.
The SSL5257TE can start up and operate in switching mode directly from the rectified mains. To provide a low-cost driver design, an off-the-shelf inductor can be used, which provides flexibility in application design.
SSL5257TE主要特性和优势:
 Integrated MOSFET (10 /700 V)
 Supports most available dimming solutions
 Deep dimming level
 Flicker-free dimming..
查看全文
