[原创] Marvell 88PA6120 3D打印机系统级芯片(SoC)解决方案
关键词:系统级芯片(SoC) 3D打印机 88PA6120
时间:2015-08-25 10:24:03       作者:Marvell       来源:中电网
Marvell公司的88PA6120是高度集成的系统级芯片(SoC)解决方案,包括功能强大的处理器533MHz ARM v7和I/O功能以及专用的图像硬件加速,提供高性能和极好的图像质量.主要用在单色和彩色激光和喷墨以及多功能打印机.本文介绍了88PA6120主要特性和优势,框图以及Marvell 88PA6120 3D打印机开发套件主要特性,硬件框图和软件框图.
The Marvell® 88PA6120 is a highly integrated system-on-a-chip (SOC) solution for color and monochrome laser and ink single or multi-function printers. The 88PA6120 combines powerful processing with a host of I/O capabilities and dedicated imaging hardware acceleration to deliver high performance and excellent image quality.
The Marvell 88PA6120 integrates a powerful 533MHz ARM v7 compatible processor to handle all the application processing requirements. The 88PA6120 augments the main processor with a highly-configurable hardware pipeline that supports scan as well as multiple printing technologies. It enables data correction and filtering, color space transformations and several half toning methods, as well as technology-specific operations like laser trapping or inkjet depletion. With pixel processing rates of up 200 Mpixel/sec and higher, it supports even the fastest printing needs. The direct engine control interface supplies highly integrated motion control of print and scan..
查看全文
