[原创] ST STM32W108无线MCUZigBee网关解方案
关键词:ARM Cortex-M3 MCU RF4CE 6LoWPAN ZigBee IEEE 802.15.4
时间:2015-07-16 13:21:25       作者:ST       来源:中电网
ST公司的STM32W10是集成了2.4 GHz, IEEE 802.15.4兼容收发器的32位ARM Cortex-M3微处理器,闪存和RAM存储器和外设的全集成系统级芯片(SoC),用于设计基于IEEE 802.15.4的系统.主要用在RF4CE产品和遥控,6LoWPAN和定制协议,以及基于IEEE 802.15.4的网络协议.本文介绍了STM32W108C8主要特性,框图,STM32W108B-SK和STM32W108C-SK入门板主要特性,MB851和MB854应用板电路图与材料清单.
The STM32W108C8 is a fully integrated System-on-Chip that integrates a 2.4 GHz, IEEE 802.15.4-compliant transceiver, 32-bit ARM® Cortex™-M3 microprocessor, Flash and RAM memory, and peripherals of use to designers of 802.15.4-based systems.
The transceiver utilizes an efficient architecture that exceeds the dynamic range requirements imposed by the IEEE 802.15.4-2003 standard by over 15 dB. The integrated receive channel filtering allows for robust co-existence with other communication standards in the 2.4 GHz spectrum, such as IEEE 802.11 and Bluetooth. The integrated regulator, VCO, loop filter, and power amplifier keep the external component count low. An optional high performance radio mode (boost mode) is software-selectable to boost dynamic range.
查看全文
