[原创] TI LMZ31710 10A DC-DC电源转换解决方案
关键词:电源管理 DC/DC转换器 SIMPLE SWITCHER电源模块 LMZ31710
时间:2015-02-26 10:50:48       作者:TI       来源:中电网
TI公司的LMZ31710是容易使用的10A SIMPLE SWITCHER电源模块.采用10x10x4.3 mm QFN封装,器件集成了功率MOSFET,屏蔽电感和无源元件,组成完整的10A DC/DC转换器,效率高达95%,热阻13.3℃/W.输出电压从0.6V到5.5V可调,可调开关频率200 kHz到1.2 MHz,主要用在宽带和通信设备,自动测试和医疗设备,DSP和FPGA点负载应用以及PCI / PCI Express / PXI Express.本文介绍了LMZ31710主要特性,框图,应用电路,以及10A LMZ31710评估模块(EVM)特性,电路图,材料清单和PCB元件布局图.
The LMZ31710 SIMPLE SWITCHER power module is an easy-to-use integrated power solution that combines a 10-A DC/DC converter with power MOSFETs, a shielded inductor, and passives into a low profile, QFN package. This total power solution allows as few as three external components and eliminates the loop compensation and magnetics part selection process.
The 10x10x4.3 mm QFN package is easy to solder onto a printed circuit board and allows a compact point-of-load design. Achieves greater than 95% efficiency and excellent power dissipation capability with a thermal impedance of 13.3°C/W. The LMZ31710 offers the flexibility and the feature-set of a discrete point-of-load design and is ideal for powering a wide range of ICs and systems. Advanced packaging technology affords a robust and reliable power solution compatible with standard QFN mounting and testing techniques...
查看全文
