[原创] Linear LTC3305电池充电平衡器解决方案
关键词:电源管理 电池充电器 电池平衡 LTC3305
时间:2015-02-12 11:23:36       作者:Linear       来源:中电网
Linear公司的LTC3305是四个串接铅酸电池平衡器,集成了所有的电压检测,栅极驱动和故障检测电路.LTC3305可单独工作而不需要任何外接控制电路.主要用在通信备份系统,工业电力汽车,能源存储系统(ESS)和医疗设备.本文介绍了LTC3305特性,框图和几种应用电路,以及铅酸电池平衡器演示板2043A主要指标,电路图和材料清单.
The LTCR3305 balances up to 4 lead-acid batteriesconnected in series. All voltage monitoring, gate drive,and fault detection circuitry is integrated. The LTC3305is designed for standalone operation and does not requireany external control circuitry.
The LTC3305 employs an auxiliary battery or an alternativestorage cell to transfer charge to or from each individualbattery in the stack. A mode pin provides two operatingmodes, timer mode and continuous mode. In timer mode,once the balancing operation is completed, the LTC3305 goes into a low power state for a programmed time and thenperiodically rebalances the batteries. In continuous mode,the balancing operation continues even after the batteries are balanced to their programmed termination voltage.
The LTC3305 is available in a thermally enhanced 38-leadTSSOP package.
LTC3305特性:
Single IC Balances Up to Four 12V Lead-AcidBatteries in Series
All NFET Design
Stackable to Balance Larger Series Battery Packs..
查看全文
