OnSemi NCL30081 3.6W反激式阶梯可调光LED设计方案
关键词:电源管理 LED驱动器
时间:2013-08-19 11:31:26       来源:中电网
OnSemi公司的NCL30081是一款定位在隔离反激式拓扑和非隔离恒流拓扑的PWM电流模式控制器。该控制器采用准谐振模式提供高效率,这种新颖的控制方法可以从原边精确控制输出恒定LED电流,该控制输出通过副边反馈电路系统、偏置电路和一个光耦合器实现。本文首先介绍芯片的简介、特性、内部框图及应用领域,并给出相应设计方案的设计原理图、元器件列表及PCB元件布局图。
The NCL30081 is a PWM current mode controller targeting isolated flyback and non−isolated constant current topologies. The controller operates in a quasi−resonant mode to provide high efficiency. Thanks to a novel control method, the device is able to precisely regulate a constant LED current from the primary side. This removes the need for secondary side feedback circuitry, biasing and an optocoupler.
The device is highly integrated with a minimum number of external components. A robust suite of safety protection is built in to simplify the design. This device is specifically intended for very compact space efficient designs. It supports step dimming by monitoring the AC line and detecting when the line has been toggled on−off−on by the user to
reduce the light intensity in 5 steps down to 5% dimming.
NCL30081主要特性:
• Quasi−resonant Peak Current−mode Control Operation..
查看全文
