ADI ADP2442 1A同步降压稳压器设计方案
关键词:电源管理 DC/DC 降压稳压器
时间:2013-01-18 16:14:07       来源:中电网
ADI公司的ADP2442是一款高效、同步、恒定频率、电流控制模式降压型DC/DC稳压器,该芯片具有优秀的负载稳压特性,负载驱动能力可达到1A。ADP2442具有较宽的输入电压范围(4.5V-36V),可以应用于多种稳压输入源,输出电压范围为0.6V-0.9*Vin。ADP2442具有过流保护、过热保护、欠压锁定等多种内部保护功能。本文通过总结ADP2442器件的特点,介绍器件、特性、应用方向及内部结构框图,并给参考设计实例原理图、制板图及元器件清单。
The ADP2442 is a constant frequency, current mode control, synchronous, step-down, dc-to-dc regulator that is capable of driving loads of up to 1 A with excellent line and load regulation characteristics. The ADP2442 operates with a wide input voltage range from 4.5 V to 36 V, which makes it ideal for regulating power from a wide variety of sources. In addition, the ADP2442 has very low minimum on time (50 ns) and is, therefore, suitable for applications requiring a very high step-down ratio.
The output voltage can be adjusted from 0.6 V to 0.9 × VIN. High efficiency is obtained with integrated low resistance N-channel MOSFETs for both high-side and low-side devices.
The switching frequency is adjustable from 300 kHz to 1 MHz with an external resistor. The ADP2442 also has an accurate power-good (PGOOD) open-drain output signal.
查看全文
