Keil NXP LPC1114 ARM Cortex-M0 32位MCU开发方案
关键词:消费类电子 白色家电;工业控制 仪器仪表
时间:2012-03-30 11:12:57       作者:Keil       来源:NXP
Keil公司的MCB1000评估板能用来评估基于NXP公司的ARM Cortex™-M0和 Cortex-M3器件如NXP LPC11xx 和NXP LPC13xx系列,具有串行接口,CAN接口和USB 2.0全速接口以及Cortex下载和调试,而NXP公司的LPC1110/11/12/13/14/15是基于ARM Cortex-M0低成本的32位MCU,CPU工作频率高达50MHz,可用于8/16位MCU的应用如电子计表,照明,告警系统工程和白色家电。本文介绍了LPC1110/11/12/13/14/15主要特性和优势,方框图以及Keil MCB1000评估板主要特性和技术数据,方框图与电路图。
The LPC1110/11/12/13/14/15 are a ARM Cortex-M0 based, low-cost 32-bit MCU family, designed for 8/16-bit microcontroller applications, offering performance, low power, simple instruction set and memory addressing together with reduced code size compared to existing 8/16-bit architectures.
The LPC1110/11/12/13/14/15 operates at CPU frequencies of up to 50 MHz.
The peripheral complement of the LPC1110/11/12/13/14/15 includes up to 64 kB of flash memory, up to 8 kB of data memory, one Fast-mode Plus I2C-bus interface, one RS-485/EIA-485 UART, up to two SPI interfaces with SSP features, four general purpose counter/timers, a 10-bit ADC, and up to 42 general purpose I/O pins.
LPC1110/11/12/13/14/15主要特性和优势:
 System:
 ARM Cortex-M0 processor, running at frequencies of up to 50 MHz.
查看全文
